Winter is Coming
I built a press of sorts to straighten the ribs on my running boards. I assume your '46 has the same ribs on it as the AD trucks. Here's a couple of pictures of what I built. I got a bracket for a bench of some sort at the ReStore and went from there, using some remnants from the USS Missouri rear bumper from my truck, but you could build one from raw steel.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
