Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (klhansen, carbking, 1 invisible), 286 guests, and 6 robots.
Topics128,283
Posts1,058,521
Members48,490
#1287164 11/12/2018 4:50 PM
I have a 1946 1/2 ton pu running board that it looks like some one has jumped on it and slightly bent running board in a down ward direction at the front bracket and the bracket didn't move. I'm not sure how to go about straitening it out with out making it worse. Can some one give me some advise on how to fix this with out making it worse. Looks like the damaged area is about 3/16 with no creases.
I built a press of sorts to straighten the ribs on my running boards. I assume your '46 has the same ribs on it as the AD trucks.
Here's a couple of pictures of what I built. I got a bracket for a bench of some sort at the ReStore and went from there, using some remnants from the USS Missouri rear bumper from my truck, but you could build one from raw steel.
Thanks Kevin that looks like it will work Don
