| | | Forums66 Topics128,050 Posts1,055,675 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Both ends of the power piston cylinder have a piece of high pressure steel tubing that goes to the spool valve located on the pinion shaft. Connecting those two ports with a single piece of tube with a standpipe type vent tube teed into the middle should allow a few ounces of PS fluid or any other oil-based lubricant to circulate from end to end. A tall vent tube off the tee should prevent hydraulic lock in case you overfill things a little, and also provide a place to add fluid when necessary. Think outside the box- - - - -"I know the voices in my head aren't really there, but boy, do they come up with some good ideas!" LOL! Jerry
