4:1= 5 sprayable quarts. 10%-20% reducer can be used if needed. My comment of 5 quarts being enough is my opinion, no one can say for sure. Not knowing how many coats. I based on two base coats and using a proper color primer. If the poster uses local company, that will be safer unless he buys 8 qts SS or 10 qts BC/CC from Eastwood. I advised him to do the math if he is on a tight budget.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn |
