| | | Forums66 Topics128,127 Posts1,056,674 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,100 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,100 | Joe, The ratio adapter was could have been installed because the 25 tooth gear wasn't correct and that was their attempt to fix it. I seems to me that the ratio adapter would have cost more than trying several cheaper plastic gears to get it right. It may have been that there wasn't anything else available at the time. If it has a 3:90 rear end the original (steel) gear had 19 teeth. The drive gear was larger to fit that configuration. The car transmission used a smaller drive gear and there are more options available with the plastic driven gears. 55-57 cars had a wide variety of rear end options from 4:10 through 3:36 and speedometer gears to match. 1/2 ton trucks had a 3:90 standard or a 4:10 if it came with OD. Fred
1956 3100 Pickup/Red/350/3sp OD/PS/Disc Brakes 1957 Bel Air Sport Coupe/Red/355/TH350/PS/Disc Brakes 2017 Silverado LT Single Cab SB/Black/5.3/6 Speed Trans 1947 Willys CJ2A w/F-Head engine
