My spare 503 distributor is driven by a rectangular shaft crosswise through a vertical 3/8" pin that extends out the bottom of the housing. The rectangular shaft is offset slightly from the center of the 3/8 shaft, one must be careful when inserting in block.
Innards of distr. are probably same as other GM distributors, however.
Ed
