In my everlasting saga of king pin replacement, I have hit another snag.
The king pin replacement kit I purchased came with metal bushings for the spindles. The bushings fit the pin perfectly but they are too loose in the spindles by a 16th. Is this something that is common and what have you fellas done in the past to correct this?
1950 suburban stock everything.
1950 SUBURBAN / SCHOOL BUS A.K.A "THE SCHOOL RUST"
