7 members (Doug Boudreaux, Jethro in Va, Possum, 1955 1 Series, Pre '68 Dave, Oswald, Bill Hanlon),
81
0
Mod | | | Forums66 Topics128,197 Posts1,057,400 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 2,237 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,237 | Joe,
Here is what I recently learned through trial and error (and getting schooled on here) 1. Odometer is run off the “tit”/ male portion of the cable. 2. There is a shoulder looking part above the tit that connects to the speedo part through a magnet. If the magnet is week, or not seated correctly, speedo will not read correctly due to slippage. 3. Guys here recommended that I tested mine by driving a known distance (Ie 10 miles on interstate) and observe how far odometer travels. Ie mine traveled 8.8 miles so it proved mine was off by certain percentage. (I am purchasing gear to compensate in the future) 4. I am also using cell app for speedo to check MPH so I can accurately guess actual speed. 5. I had issues with my cable not seating correctly. You can either try reconnecting it to ensure it is back correctly or leave one end hooked to your transmission (other end unhooked) and have a passenger observe to ensure it is spinning when driving. (I both)
I know that this doesn’t answer your questions, but might narrow down the issue.
Chris | | | |
Entire Thread
Speedomter ratio adapter questions 1/2 ton, C3100, 3 spd manual
| Joe Finkelstine | 07/11/2018 2:52 PM |
Re: Speedomter ratio adapter questions 1/2 ton, C3100, 3 spd manual
| ndkid275 | 07/11/2018 3:35 PM |
| Joe Finkelstine | 07/11/2018 4:55 PM |
| ndkid275 | 07/11/2018 6:47 PM |
| Joe H | 07/11/2018 11:44 PM |
| Joe Finkelstine | 07/13/2018 12:49 AM |
| Gord&Fran | 07/13/2018 4:25 AM |
| ndkid275 | 07/13/2018 5:22 AM |
| Joe H | 07/13/2018 12:18 PM | |
