| | | Forums66 Topics128,113 Posts1,056,618 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | Alvin,
My '36 Chevy pickup has a "hair trigger" clutch engagement and I understand that problem wasn't solved until the 1938 model year. I really have to pay attention to get smooth clutch engagement. There is no progressive feel to it. If I had the restoration to do over I'd adapt a late model pressure plate onto the '36 flywheel. I have a 1971 Dodge van that bought new and its clutch engagement has always been silky smooth. Even from a stop on a steep uphill the clutch is perfectly smooth and easy to operate.
I'd find a modern pressure plate the right diameter and use that. Your friend should also resurface the flywheel while it's accessible.
Ray
