8 members (cmayna, Woogeroo, walter74, Ponchogl, Hotrod Lincoln, baldeagle, 2 invisible),
348
3
Mod | | | Forums66 Topics128,165 Posts1,057,087 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 123 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 123 | I guess I really messed up the valve timing and setting the screws on the pushrods. Just did a compression test and only cyl #4 registered 120lbs. The other 5 cylinders had zero. back to the beginning. by the way it is a 235 hit the wrong key Martin. | | |
