1 members (baldeagle),
51
3
Mod | | | Forums66 Topics128,003 Posts1,055,244 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,740 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,740 | The pinion shaft is the one the universal joint flange is attached to. You need to measure the movement of the ring gear, not the pinion. Use a magnetic base dial indicator or one with a C-clamp mounting attached to a long bolt screwed into one of the cover attaching bolt holes and position the stem of the dial indicator as close to 90 degrees from the movement of the ring gear as possible. Measure the amount of slack there is while rocking the ring gear forward and back. Unless the slack is WAY out of specification, don't mess with any adjustments. You are almost guaranteed to create a gear whine by changing the wear pattern the gears have established over decades of operation. I'd consider anything under .025" or so of backlash to be in the "DON'T MESS WITH IT" category. More than that- - - - -go shopping for another third member- - - -it's worn out! Jerry
