Originally Posted by old norse
Upon further review of problem appears that crescent shaped gear which engages round gear on window crank does not travel its entire length.
Is one of the teeth on the crescent gear damaged so that it hangs up at that spot when it tries to engage with the crank gear?
Kevin
1951 Chevy 3100 work truck
Photos
