1 members (52Carl),
105
2
Mod | | | Forums66 Topics128,062 Posts1,055,845 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | Pete, There are a number of aftermarket sources that sell what is now referred to as a "Series 400" power steering unit. It is really a recreated Toyota box (84-87 4x4 truck) which now incorporates a cast mount that lines up directly with the existing mount holes on a TF frame. I converted my 56 in 2000 and it works great. I used the stock column which I modified to adapt to the PS box. I also retained the entire column shift components for the 3 speed overdrive. I have done several of these conversions. If you wish to contact me, I can provide additional information. Fred
1956 3100 Pickup/Red/350/3sp OD/PS/Disc Brakes 1957 Bel Air Sport Coupe/Red/355/TH350/PS/Disc Brakes 2017 Silverado LT Single Cab SB/Black/5.3/6 Speed Trans 1947 Willys CJ2A w/F-Head engine
