| | | Forums66 Topics128,059 Posts1,055,825 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 206 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 206 | I'm looking for advise on how best to add power steering to taskforce ( 1958 ) 1/2 ton with original steering column. Can it be done? The truck has a 383 cab. I'd like to retain look inside cab and keep original column and steering wheel. I always appreciate everyone's thoughts here Thanks. | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | Pete, There are a number of aftermarket sources that sell what is now referred to as a "Series 400" power steering unit. It is really a recreated Toyota box (84-87 4x4 truck) which now incorporates a cast mount that lines up directly with the existing mount holes on a TF frame. I converted my 56 in 2000 and it works great. I used the stock column which I modified to adapt to the PS box. I also retained the entire column shift components for the 3 speed overdrive. I have done several of these conversions. If you wish to contact me, I can provide additional information. Fred
| | | | | Joined: Oct 2015 Posts: 338 Shop Shark | | Shop Shark Joined: Oct 2015 Posts: 338 | Thanks for the information share Fred! I love it when guys like you offer to help! | | |
