I got mine from Jim Carter as well. Good to know that you found them satisfactory. I did see that you needed to extend both, but that was probably just because your rust extended past the patch panel size. Did you have the cab on a rotisserie or just stand it on it's top?
Kevin
1951 Chevy 3100 work truck
Photos
