Hy oldieoldie, I noticed you posted on another post that you can't find parts to repair the brakes on your truck, as I stated previously the brake parts on your front axle are those of a truck no newer than a 1950 model, you keep identifying your truck as a 1952 model. Could you please post your trucks serial number here so we may decipher it and identify exactly what you are working on. There is no point in giving you part numbers for brake components for a 1952 model if your truck is actually a 1950 model (which uses a different type of brake system). I know that your front brakes are for a 1950 model, but maybe somewhere along the line someone swapped in an older front axle, please post your trucks serial number so that we can be sure what we're dealing with, thank you.
