Originally posted by Brian:
Those pictures show how to do it, not sure why Craig removed the piece mounted to the frame, they are riveted on.
Craig's is also probably a reproduction one. If yours is original, it is quite rare and valuable, since you will soon learn they are a real PIA and most have been trashed long ago by previous owners.
Huh? Sorry but what you see in the pics has nothing to do with the fix running track that is still riveted to the frame.
Ala,
When you click on the above pic, you come to Webshots, yes? Look in the upper RH corner. Don't you see "next"?
Denny, that is correct. It is a repro.
