1 members (TPR57C),
367
Mod | | | Forums66 Topics128,159 Posts1,057,033 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 44 Member | | Member Joined: Apr 2007 Posts: 44 | Trying to assemble spare tire carrier parts that came with the truck, there is a slide type bar apparatus mounted to chassis and then I have a long 3 ft or so piece with a J bolt in it that appears to be the lower tire rest on piece, then two other brackets, one a small bracket with round side to it, and the other bracket about 18 inches that has two mounting holes that line up with the smaller round brakcet piece, I have the chevy assembly manual and shop manuals for this year and they show an entirely differrent set up, I think this is some kind of swing down and to rear appartus, any help or drawing of how it goes together and works will be greatly appreciated | | | | | Joined: Jan 2002 Posts: 2,843 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,843 | Ala, Click on the below pic to see the spare tire set up I use on my 50. Hit the next button at upper right to see more pics. I assume the channel that is attached to your frame runs lengthwise down the center? Yes it is a swing down. After you unloosen the J bolt the tire and it's mounting bracket drops to the ground (careful, heavy) You then pull the assy out from under the bed by sliding it along the channel that is attached to frame. [img]http://thumb2.webshots.net/s/thumb1/7/35/75/114973575pUdYxE_th.jpg[/img]
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | Those pictures show how to do it, not sure why Craig removed the piece mounted to the frame, they are riveted on. Craig's is also probably a reproduction one. If yours is original, it is quite rare and valuable, since you will soon learn they are a real PIA and most have been trashed long ago by previous owners. | | | | | Joined: Apr 2007 Posts: 44 Member | | Member Joined: Apr 2007 Posts: 44 | Thanks for the help gentlemen Take care Ken | | | | | Joined: Apr 2007 Posts: 44 Member | | Member Joined: Apr 2007 Posts: 44 | Craig when i clicked on your my truck link it took me to a single picture, no option to see more it was just a jpg of your fine looking nice truck that I know you are proud to have. Let me know how to see the spare tire pics Take care Ken | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | The way that carrier is cut up and re-welded in numerous places Craig, it's obviously not stock is it??? Denny G
Denny G Sandwich, IL
| | | | | Joined: Jan 2002 Posts: 2,843 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,843 | Originally posted by Brian: Those pictures show how to do it, not sure why Craig removed the piece mounted to the frame, they are riveted on. Craig's is also probably a reproduction one. If yours is original, it is quite rare and valuable, since you will soon learn they are a real PIA and most have been trashed long ago by previous owners. Huh? Sorry but what you see in the pics has nothing to do with the fix running track that is still riveted to the frame. Ala, When you click on the above pic, you come to Webshots, yes? Look in the upper RH corner. Don't you see "next"? Denny, that is correct. It is a repro.
| | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | Craig, picture #3 shows the upper track, and it is not on the frame. That is what I am talking about. Mine is riveted in place. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Jan 2002 Posts: 2,843 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,843 | Originally posted by Brian: Craig, picture #3 shows the upper track, and it is not on the frame. That is what I am talking about. Mine is riveted in place. Brian, My error. Sorry about that. Now that I studied the pic I remember that the track on my truck was not riveted. Just bolted on. Maybe the PO drilled out the rivets.
| | | | | Joined: Mar 2005 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 92 | On my '50 the rail just bolted in just like Craigs, no rivets. | | |
