| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | If the adjusters are on the ends of the wheel cylinder, you've got Huck brakes. Bendix brake shoes free-float at the bottom and they have one adjuster that moves the shoes away from each other, also at the bottom. Bendix brakes started in 1950 or 51 on the 1/2 ton trucks- - - -not sure when the switch was made on the bigger ones. Jerry
