| | | Forums66 Topics128,014 Posts1,055,333 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | You can see in this photo before the option of the column shift 1947- early 48 truck period there is no hump. There is a different bracket assembly as well. The column support nuts are square and fit in a recess to provide clearance (tight). https://www.flickr.com/photos/advance-design_parts_co/17058543159/in/album-72157651718017649/Once the column shift was introduced the bracket, dash all changed. https://www.flickr.com/photos/advance-design_parts_co/17056942878/in/album-72157651722976780/Brackets showing correct nuts/washers. Often if the original, un-modified bolts are in place and you loosen them without liberal let-go being used, they turn or snap. If they turn, they often damage the column support under the dash. This area collects a lot of dirt and moisture over the years. On the end of the bracket you can see, adjustment and tabs which get damaged. https://www.flickr.com/photos/advance-design_parts_co/29357264511/in/album-72157631868452754/https://www.flickr.com/photos/advance-design_parts_co/8129347267/in/album-72157631868452754/Here you can also see the difference in the gauge clamp brackets, early gauges are unique. https://www.flickr.com/photos/advance-design_parts_co/13748869504/in/album-72157631868452754/Another column support bracket, this unique to the COE models. https://www.flickr.com/photos/advance-design_parts_co/32593170513/in/album-72157631868452754/This is the 54-55 1st version, cost saving in all it's glory here. https://www.flickr.com/photos/advance-design_parts_co/19621702721/in/album-72157631868452754/ | | |
