8 members (David Bush, kades51, BC59, MikeE, Bucker, MickeyP, Rexville48, dt235sd),
97
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,702 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2002 Posts: 394 'Bolter | | 'Bolter Joined: Nov 2002 Posts: 394 | Well in a hurry and disonnected my dimmer swicth witout remembering where my 3 wires connect. there is a light blue, tan and light green wires, I'm almost sure the light green, the upper beam goes in the middle.Now, does the battery (light blue) go on top of the switch or the bottom? 1 more question on the head light switch does it ground to the dash board when you tighten up the nut or do you ground it with a wire from the swicth itself? Thank you......... | | |
