| | | Forums66 Topics128,049 Posts1,055,699 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2002 Posts: 394 'Bolter | | 'Bolter Joined: Nov 2002 Posts: 394 | Well in a hurry and disonnected my dimmer swicth witout remembering where my 3 wires connect. there is a light blue, tan and light green wires, I'm almost sure the light green, the upper beam goes in the middle.Now, does the battery (light blue) go on top of the switch or the bottom? 1 more question on the head light switch does it ground to the dash board when you tighten up the nut or do you ground it with a wire from the swicth itself? Thank you......... | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | your dimmer switch does not need a ground. All it does is send + to either high or low beams. Sorry, I don't know off the top of my head which wires go where, should be real easy to figure out with an ohm meter though. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The light blue is the power switch. The light green is high beam. Tan is low beam. If you hook the power wire to the correct term. it doesn't matter which ones go to the other terms. The light switch grounds through the metal dash. It has to be grounded for the dome light to work off of it. George
They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2002 Posts: 394 'Bolter | | 'Bolter Joined: Nov 2002 Posts: 394 | Dam, what would I do without you Bolters? I just don't get Ohms law very well do I? Thanks there fellahs........ | | |
