Just got back from test drive after putting tranny in standard mode? Nice to be able to use engine compression to slow down, that free wheeling always seemed kind of strange? During the drive noted slight vibration in drive shaft? PO has shortened it, welded right in the middle? Also noted brake pull on panic stop. Any information on tranny #'s will be appreciated.
Phil
Transmission # GM 3 3845122
L104
6
R10H-1
WG DIV
Side plate #3845044GM
Fred, thanks for the information
