Not sure I would want to remove 3 inches of suspension travel from my front suspension...which is what happens when you use lowering springs as opposed to dropping the axle.
When your truck is sitting on it's wheels, how much clearance do you have right now between the frame and the front leaf spring bump stop?
~ Dave
1950 Chevrolet 3600 3/4-ton with 261 engine & T5 Transmission
