I've seen cab/chassis vehicles built to utility bed truck have a 3-4' or more filler hose. The problem with the Suburban/Panel is that the hole is pretty low on the body. You might have nozzle click off problems with the fuel backing up the hose. It might take a little engineering, but it is probably possible.
