| | | Forums66 Topics128,130 Posts1,056,712 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2014 Posts: 1,291 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,291 | Fox, I measured mine at the top of the threaded holes and I got 60.187 ( 60 3/16 ) . Its kind of difficult to do by oneself............I can see that because the threaded holes are "angled" that the farther away you go from the face of the threaded holes ( as in the hinge being bolted on) that the distance will be greater so I'm thinking that your measurement is probably very accurate. Hope this helps rmw667 .
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | |
Entire Thread
need a measurement, lower door hinge bolts
| rmw667 | 01/05/2018 3:15 AM |
Re: need a measurement, lower door hinge bolts
| Achipmunk | 01/05/2018 3:32 AM |
| rmw667 | 01/05/2018 3:34 AM |
| Achipmunk | 01/05/2018 3:42 AM |
| bowtietim | 01/05/2018 3:58 AM |
| tclederman | 01/05/2018 4:12 AM |
| jorb | 01/05/2018 5:05 AM |
| rmw667 | 01/05/2018 3:04 PM |
| Dusty53 | 01/05/2018 7:33 PM |
| Fox | 01/06/2018 12:44 AM |
| Dusty53 | 01/07/2018 2:34 AM |
| Fox | 01/09/2018 5:15 AM |
| Dusty53 | 01/10/2018 2:09 AM | |
