0 members (),
80
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,741 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2017 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2017 Posts: 36 | It looks like the 56 and earlier clutch forks are different from the 57 and later. early being bent and later being straight . I am using a later bell housing and have a straight fork with it,. The plan is to change the motor and transmission as a unit so hopefully is a quick and simple swap from the 283 and 3 speed to a 350 and T5. So the question is will the straight fork work with the 56 linkage , or do I need to have a bent fork like what is in it now. Is a 56 3100 Thank You Charles | | |
