| | | Forums66 Topics128,005 Posts1,055,261 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 155 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 155 | I couldn't find an exact breakdown of the code you have posted, but I did find a "TA" code that was used for the '65 230 and the '66-'68 250 used in 2wd C10 trucks with manual transmission. It seems that your code is missing one character, as it should have letter for the plant code (F is usually Flint) then a Month/Day code, and lastly, the application code. You might check for a casting date somewhere on the block or head. I can't really give you an exact location on that generation of Chevrolet 6, as my knowledge is more with the earlier 216/235/261, but you might look somewhere near the starter. Thanks I will try to get a better block ID number as its pretty rough
I have a 55 second gen!,, work in progress 1963 long bed step side driver Just a guy who digs old trucks! | | |
