| | | Forums66 Topics128,031 Posts1,055,434 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#12435 07/20/2004 4:47 PM | Joined: Feb 2000 Posts: 985 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 985 | I dont think that is correct. I may be wrong but I have always thought that compression ratio is the difference between the volume of the piston at top dead center and bottom dead center. Now like I said I might be wrong but I doubt that you can make a correlation between psi and compression ration.
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
