| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,776 | See if you can do a forum search and find my "companion cylinder" adjustment method. I get tired of writing it repeatedly, especially since nobody seems to be using it anyway. It's the most accurate method of being sure the cam lobes are exactly positioned for a good valve adjustment, even with a radical-grind racing cam. Jerry
