| | | Forums66 Topics128,119 Posts1,056,313 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | My toe board has a rectangular depression about 1.5" wide by 0.5" high about 2" below the steering column and clutch pedal. It also has 2 holes in it. Can anyone tell me what goes here? A rubber block for the clutch pedal to contact when you let off the clutch.
Also, further down, near the bottom edge, is a 5" pressed "ridge", about 1/2" high. On the back side of this are two strips of metal that look like they retain something in the depression of this ridge. What is this all about?Not sure just reinforcement for the kick board I think. | | |
