Hello Fellas, I did it!! I figured out how to get t he steering wheel off the column. What I did was, I removed the horn button down to the nut that holds on the steering wheel. Then I put penetrating oil on the threads. Then just used a large rubber mallet and tapped up on the steering wheel on one side then the other, and it popped off. On the steering gear box, I just removed all the bolts that hold it onto the frame and then used a gear puller and removed the pitman arm. Worked pretty slick. Thanks guy's for the support!!
Steve
