Oh yeah quite a bit larger in fact. Have seen guys use them but not the best solution. 3/4 ton trucks are a better option but don't bolt up to running boards like the half tons do. Cab, hood, grille, etc are the same. don't have an answer re. the 19.5 wheel. Best of luck
