| | | Forums66 Topics128,118 Posts1,056,305 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | It would probably cost less and create less work to have the original box rebuilt. The sector shaft comes out the bottom of the 60-66 gear box, so pitman arm and drag link mods would have to be made. Also some sort of mounting bracket would be needed. Many street rodders use a Vega box on 30's cars, so that may be a possibility. There are flex joints available to use an aftermarket column. It still would require a drag link and pitman arm to connect to the original steering components. Fred
1956 3100 Pickup/Red/350/3sp OD/PS/Disc Brakes 1957 Bel Air Sport Coupe/Red/355/TH350/PS/Disc Brakes 2017 Silverado LT Single Cab SB/Black/5.3/6 Speed Trans 1947 Willys CJ2A w/F-Head engine
