| | | Forums66 Topics128,114 Posts1,056,283 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Is there a preferred way to assemble the inner and outer fenders to the cab and core support? I have seen guys assemble the inner fenders to the outer fenders then as a combined assembly attach them to the cab and radiator core support. I am finishing up on the paint work and since I do not have help regularly, I need to do this myself and hopefully without screwing up my paint. If I am to attach each part individually, do I hang the outer fender before the inner or vise versa? Thanks in advance. 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
