Jerry is referring to the high-pressure 235 engine, probably because of the reference to an odd mounting hole?
If the 235 in question is a 1941-1953 low pressure 235, the water pump would be in the correct location for 1955st and earlier trucks.
704josh, do you know the year of your 235?
What is the engine serial number pressed into the block to the rear of the distributor?
