Is there a correct way to mount the passenger door lock in a 1946?
Should the lock be in the open or locked position when installing the rod from the key cylinder?
Should the key/cylinder be in the lock or unlock position or in "center"?
Thoughts will be appreciated.
Harold
Harold
Is a restoration ever finished?
