8 members (Oldcaliforniakid, Otto Skorzeny, jmoore, frogfarmer, Hotrod Lincoln, 49nut, Stovebolt48, mason86),
114
0
Mod | | | Forums66 Topics128,050 Posts1,055,671 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Is there a correct way to mount the passenger door lock in a 1946? Should the lock be in the open or locked position when installing the rod from the key cylinder? Should the key/cylinder be in the lock or unlock position or in "center"? Thoughts will be appreciated. Harold
Harold Is a restoration ever finished? | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | I believe I put mine in with both in the open position, but not sure if it matters as long as both are the same position. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | Harold I don't know if my experience with the '37 is applicable, but my recollection is the key/cylinder was in the unlock position. Note: the cylinder is in the handle in '37 models. Given the '46's are in the door, it might be otherwise? | | | | | Joined: Jun 2016 Posts: 236 DLBrooks | | DLBrooks Joined: Jun 2016 Posts: 236 | I just put one in a 46 in the open position. I had to jiggle it a little ---slight turn --to get the square rod to slide thru. | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Tried it in open position & set the arm on the latch to open, put it together and it works!!! One more project done. Thanks for all your comments. Harold
