| | | Forums66 Topics128,132 Posts1,056,383 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 393 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 393 | I have come across an SM420 transmission with the driveshaft braking system attached. I realize that these systems were used in the bigger bolts. Is the parking/e brake system able to be removed? Would I be able to use this transmission in a 1/2 ton (if the brake is able to be removed?
It's a small world, but I wouldn't want to paint it.
