Jerry is right, the best way to get to it is pull it. On the other hand, if you had a dental tool and could see in there well enough to grind a hole in the center deep enough, you could do that and possibly get it out with an easy-out. That would probably take almost as long as dropping the bellhousing though. Bummer though!
