No takers on that one... I left around 5/8"-3/4" if anyone is interested. I've also scribed my lumber over the axle hump, here's a pic:
https://goo.gl/photos/wfxEyC7z46JYLnePA
On the passenger side, the fuel filler neck for the 'under-bed' tank sits about an inch or so off the frame. I was trying to decide if I should cut a nice round hole to slip it through, or if I should do a inverted "U" down to the frame. The round hole would look the best, but I'm thinking that if I need to pull the bed off for any reason, a "U" would allow it to lift straight up.
Any thoughts/suggestions?
1948 Chevy Thriftmaster 3/4-Ton
Poncho "farming" in Ontario
Starting in the DITY
Continuing in the Project Journals
More images
There are only 10 types of people in this world, those who can read binary and those who can't.
