No Teflon tape should be used. It does nasty things to the tiny holes in the carburetor.
If applied correctly, (not lapped over the end of the male threads), nothing will wind up in the system. If you do a sloppy job of wrapping, then you'll get bits of teflon tape where they don't belong.
