7 members (Gdads51, TUTS 59, Buckeye998, Robert Crandall, Greg_H, 2-Ton, 1 invisible),
362
Mod | | | Forums66 Topics128,162 Posts1,057,041 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | Another option would be a trans that was used pretty frequently ahead of a 3.08 rear axle, the TH 350C. It has a locking clutch in the torque converter that gives approximately a 10% RPM reduction at light throttle cruise by eliminating the built-in slippage in the converter. That one uses a 3-switch series of controls, a vacuum switch that senses engine load, a brake switch that disengages converter lockup anytime the brake is used, and a governor pressure switch in the valve body that sets the minimum lockup speed. All three switches must be closed to send power to the solenoid valve that locks in the converter clutch, but no computer is needed for the system to function.
BTW, converter locking clutches are nothing new- - - -the 1949 Studebaker automatic had one, and also the 55-57 Packard Ultramatic. No electrical controls were used on either one of them, however. Jerry
Entire Thread
200-4r, 3.07 rear, 350 carbed
| Cletis | 04/27/2017 1:14 AM |
Re: 200-4r, 3.07 rear, 350 carbed
| Hotrod Lincoln | 04/27/2017 1:37 AM |
| 42465967 | 04/27/2017 1:57 AM |
| Wrenchbender Ret. | 04/27/2017 3:26 PM |
| Cletis | 04/28/2017 12:51 AM |
| Wrenchbender Ret. | 04/28/2017 3:17 AM |
| Cletis | 04/28/2017 1:02 PM |
| 42465967 | 04/28/2017 7:31 PM |
| 52Carl | 04/29/2017 5:15 AM |
| Cletis | 04/29/2017 5:26 AM |
| 52Carl | 04/30/2017 4:39 AM |
| Cletis | 04/30/2017 4:21 PM |
| crenwelge | 04/30/2017 6:01 PM |
| 52Carl | 05/01/2017 3:28 AM |
| Hotrod Lincoln | 05/01/2017 5:22 PM |
| 42465967 | 05/01/2017 7:17 PM |
| Hotrod Lincoln | 05/01/2017 7:29 PM |
| tomctomc | 05/02/2017 12:15 AM | |
