7 members (Donf, Gdads51, cmayna, Otto Skorzeny, Forty9, Gray_Ghost, 1 invisible),
91
0
Mod | | | Forums66 Topics128,118 Posts1,056,307 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 592 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 592 | Lou, you might have already done this if you are concerned about air, but if not, try removing the temperature sending unit when you are filling the system. That will allow all of the air trapped inside the engine to purge through the top of the head while you are filling it. Put the fitting back in when coolant starts to flow through the hole.
Be sure that your valve cover is attached with a good gasket when you do this. If not, when the coolant weeps from the sensor hole it will flow into the exposed head. Don't ask me how I know this!!
Some guys will drill a 1/8" hole through the thermostat flange to allow trapped air to escape. I prefer to use ones with a jiggle pin that allows air to escape but also acts as a check valve to not allow coolant to flow through the air hole. The last 180 and 160 thermostats that I bought at Autozone (their Duralast store brand) both had jiggle pins.
Matt | | | |
Entire Thread
Temperature spikes, water pump failure?
| Suburban Lou | 04/26/2017 5:33 AM |
Re: Temperature spikes, water pump failure?
| Suburban Lou | 04/26/2017 5:52 AM |
| Suburban Lou | 04/26/2017 6:39 AM |
| Justhorsenround | 04/26/2017 2:37 PM |
| Suburban Lou | 04/27/2017 8:53 AM |
| tclederman | 04/27/2017 3:31 PM |
| Maybellene | 04/26/2017 2:46 PM |
| Forty9 | 04/26/2017 6:39 PM |
| Hotrod Lincoln | 04/26/2017 11:08 PM |
| Suburban Lou | 04/27/2017 1:20 AM |
| tclederman | 04/27/2017 1:31 AM |
| Suburban Lou | 04/27/2017 1:38 AM |
| Suburban Lou | 04/27/2017 2:32 AM |
| truckernix | 04/27/2017 2:33 AM |
| Norcal Dave | 04/27/2017 3:53 PM |
| Suburban Lou | 04/27/2017 5:12 PM |
| GeneWiseman | 05/21/2017 3:51 AM |
| Suburban Lou | 06/14/2017 6:18 AM | |
