1 members (Rusty Heaps),
114
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2016 Posts: 236 DLBrooks | | DLBrooks Joined: Jun 2016 Posts: 236 | If tires are 27.5 inches tall with a 3.73 rear gear then if drive gear is Pink 7 teeth then use a 19 tooth driven gear truck code J. If drive gear is black 8 teeth then use a 21 tooth driven gear truck code L.
What color is your present drive gear? On your driven gear housing it should say what driven gear teeth can be used. | | |
