| | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 11 New Guy | | New Guy Joined: Feb 2004 Posts: 11 | I have a 1949 3100 that I put in a 283 with a TH400 running a 373 rear end out of a 56 Chev. I have the stock tire size that was stock but I changed it to 15" 15-670. I am looking for some help on figuring out what speedometer gear is the right one to use. Or even one that will get me close. | | | | | Joined: Jun 2016 Posts: 236 DLBrooks | | DLBrooks Joined: Jun 2016 Posts: 236 | If tires are 27.5 inches tall with a 3.73 rear gear then if drive gear is Pink 7 teeth then use a 19 tooth driven gear truck code J. If drive gear is black 8 teeth then use a 21 tooth driven gear truck code L.
What color is your present drive gear? On your driven gear housing it should say what driven gear teeth can be used. | | | | | Joined: Feb 2004 Posts: 11 New Guy | | New Guy Joined: Feb 2004 Posts: 11 | Not sure I will take a look tomorrow. Thanks for the Info. I will post tomorrow afternoon. | | |
