I'm helping a friend with a 47 1/2 ton that has a later 235 engine in it. Originally this was a non-pressurized cooling system. Can he still run a non-pressurized radiator cap with the newer engine or does it need to be a pressure cap? The problem he's having is the heater core can't handle any pressure. It keeps developing leaks with a 5 lb. cap on it. Dave
