BASECOAT/CLEARCOAT? SINGLE STAGE? ARE YOU LOOKING FOR A SMOOTH SHOW CAR FINISH OR JUST WANT TO WAX IT? FOR A SHOW CAR FINISH (SMOOTH AS GLASS, NO ORANGE PEEL)I WET SAND AND BUFF WITHIN 2 DAYS OF PAINTING BC/CC. I START WITH 1200 GRIT THEN 1500 THEN 2000 GRIT PAPER.THE FINER THE GRIT THE LESS BUFFING YOU WILL NEED TO DO. YOU MAY ASK YOUR PAINTER IF YOU DID NOT SPRAY IT YOURSELF TO WET SAND AND BUFF IT. IF YOU DONT KNOW WHAT YOU ARE DOING WITH A BUFFER YOU CAN BURN THE PAINT. I PERSONALLY WILL NOT BUFF SOMETHING I DID NOT PAINT BECAUSE I DONT KNOW HOW MUCH CLEAR WAS APPLIED. IF YOU KNOW YOU ARE GOING TO WET SAND AND BUFF THEN YOU PUT A FEW EXTRA COATS OF CLEAR ON IT ,BECAUSE WHEN YOU WET SAND YOU ACTUALLY TAKE OFF A LAYER OR TWO. AT MINIMUM I RECOMMEND AT LEAST 30 DAYS BEFORE A GOOD ORDINARY WAX JOB. HOPE THAT HELPS
1948 Chevrolet 1.5-Ton
