0 members (),
160
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,850 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,850 | One precaution- - - -lowering the float will also create a lean condition over pretty much the entire mixture range, and will most likely cause a flat spot in the transition from idle to midrange RPM. Ideally, the float level needs to be just barely below the level of the venturi so it only needs a little extra airflow above idle to start the fuel flow in the main metering circuit. Jerry
Entire Thread
dropping float height in carter webers, 56 235 motor
| Sharon Danella | 02/12/2017 6:29 AM |
Re: dropping float height in carter webers, 56 235 motor
| beltfed | 02/12/2017 2:24 PM |
| truckernix | 02/12/2017 3:29 PM |
| Hotrod Lincoln | 02/12/2017 3:52 PM |
| Wrenchbender Ret. | 02/12/2017 6:20 PM |
| beltfed | 02/12/2017 10:47 PM |
| Sharon Danella | 02/13/2017 3:36 AM |
| tclederman | 02/13/2017 3:52 AM |
| Sharon Danella | 02/13/2017 3:54 AM |
| Sharon Danella | 02/13/2017 4:03 AM |
| Sharon Danella | 02/13/2017 4:13 AM |
| Joe H | 02/13/2017 5:18 PM |
| Sharon Danella | 02/13/2017 6:15 PM |
| Sharon Danella | 02/13/2017 11:09 PM |
| Sharon Danella | 02/13/2017 11:13 PM |
| tclederman | 02/13/2017 11:39 PM |
| beltfed | 02/14/2017 12:05 AM |
| Sharon Danella | 02/14/2017 12:13 AM |
| Justhorsenround | 02/14/2017 1:10 AM |
| tclederman | 02/14/2017 2:04 AM |
| Sharon Danella | 02/14/2017 2:50 AM |
| Sharon Danella | 02/14/2017 10:15 PM |
| carbking | 02/14/2017 10:42 PM |
| wolffcub | 02/15/2017 3:42 PM |
| wolffcub | 02/15/2017 3:45 PM |
| Sharon Danella | 02/15/2017 6:14 PM |
| wolffcub | 02/15/2017 6:21 PM |
| Sharon Danella | 02/15/2017 7:26 PM | |
