| | | Forums66 Topics128,115 Posts1,056,288 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | where are you applying grease on the spindle? The bearings should slide over the spindle and are a tight enough fit that if you put a bunch of grease on the spindle, the bearing will push it up against the backing plate and make a mess. I normally just grease the bearings and races real well, a little grease on the seal, and wipe the spindle with a rag to get any dirt or brake dust off. It is fine to have a little bit of grease on it (like a film left from the rag) but not much. | | |
